phase linear 400
Gene, I'll send it to you... The Naughty Pine is coming down. Not only did they install it with no insulation and attached it right to the cement block, it is not conducive to stereo music like
new houses here are constructed to withstand earthquakes...block, steel, and cement...we survived a 7.6 a few years back...not one bit of damage except for knock knacks hitting ceramic floors...
only wood houses here are very poor erecting shacks to stay dry...
my wopl build used a 4 fin for base unit..it was a parts machine i bought from rob with the 8 fin...it only came with 1 of the 2 covers for the outputs...i added more cooling fins so now i will have to cut the covers to size...does anyone have a discarded 4 fin out out cover they want to part with???
I need two of the 4-fin (wide) transistor covers for my PL400. Gene, you have one?
yes sir..i have one...i also need another....
i made a wopl from guts of 4 fin parts machine i bought from rob..it only came with 1 wide output cover, the other was missing along with top and bottom amp covers ..i bought a new case from joe...which solved the top and bottom issue...but still no output covers...a buddy bent me extra fins to convert the 4 fin cooling to 8 fin cooling...so i am short either 2 narrow or 1 wide...i heard you could get a shock from the transistor cases???
if i can leave off covers safely or devise another type cover i will gift them...
any ideas out there???
