Works in every 400 and 700 Gene
thank you so much....i appreciate your time...and good to know...
the faqs state that the kit does not work in the very early 400s...that is what had me worried....
"Does the PL400 Capacitor Upgrade Kit work in all Phase Linear 400 Amplifiers?
It works in all but the earliest PL400s. The earliest PL400s produced had the power supply capacitors mounted directly to the left side of the amplifier chassis using 2 round capacitor brackets. The rectifier bridge was also mounted to the chassis side in this amplifier vintage. The White Oak Audio Capacitor upgrade WILL NOT install in amps of this vintage. "
my 400 fits that description....
and i just wanted to make sure that the kits will all work in my 400....i am a long way away ... better safe than sorry...
take care...
gene
ps...how do i order and pay for these kits???
