Speaker cables
I finally got a chance to clean and straighten out the Drumgeon a bit today. Found my speakers and their cables behind the crap…
Made from Swiss plasma gun power cable stock- silver plated copper strands (a lot of them) in a regular rope twist with an outer Chinese finger puzzle finish. Covered with clear shrink tubing. That is a single cable in my hand. Cable came from the scrap bin where I used to work…
This cable goes inside a water hose for cooling. The outer braid keeps the inner braid together- the gun at the end of these cables is moving around to do the spray work and the typical crimp termination is where the strands start breaking.
The inner cable has to be stretched too, because leaving it loose it can nest at the end and reduce water flow.
The American vession is tin plated, and doesn’t have the outer braid on it. The Swiss one is better!
Not intentionally, no. But a few very expensive parts have been scrapped when a turntable fails and the gun dwells in one spot...
We take powdered metal, ceramic, cermets and carbide/matrix and inject it into the plasma effluent, which heats it a bit and accelerates it toward the prepared surface. There it sticks (if we did it right), builds up and can then be used as-is, machined or ground to final dimension and surface finish.
Airplanes would not fly if not for thermal spray coatings. They are heavily relied upon and designed around.
So, you can take a soft aluminum part and apply a tungsten carbide coating to a wear location and the nice light part outperforms tool steel in the same location. That's just one example...
That’s really cool, any chance that technology could be used in audio, like coating speaker cones to make them more ridged ?
So like an esoteric spray metal operation?
Yeah, we coat those flaps.
We use high energy plasma for that. The horrible console with the really poor mass flow controller implementation I’m constantly fixing… that has three power supplies and three electrodes and the powder is injected axially.
I should have mentioned we also coat the inside of the augmentor- that white barrel in front of the flaps. That get Yttria stabilized Zirconia top coat to keep from melting.
We coated one yesterday in fact. I’ll see if I can get some pictures and then 3D can show where they go.
