krellmk
- Nov 3, 2016
- Brooklyn NY
- Are you satisfied with the life you're living
Are these things snake oil or what some of these audiophile swear these thing improve the tube sound
Did he try to sell you the Brooklyn BridgeSome guy at a audio show in NYC told me it help to reduce second-order, "harmonic" distortion, why you want to remove this harmonic which is quite musical.
A wise responseI just avoid vacuum tubes.
They are only in the pre driver of the amps, and run well below nominal. The only reason I changed them was so that I had matching tubes across both amps- my original one had the original tubes (still fine) and the other had different tubes. Michael Elliott was a fan of the Sovtek tubes, and I was a dealer prior to acquiring the second amp… got me two matched sets, threw o-rings on them and enjoyed the music.
The comments above about the phono pre are good reason to avoid them in that device. Such huge gain from such a tiny signal. You either have a half-dozen gain stages (with the additive distortion from each) or fewer with massive gain in each. Op amps are perfect in this scenario because they are so small it is very easy to optimize the power supply close to the chips. Even a discrete assembly sufferes from space- it needs room for components!
As an aside, I asked Wyn about designing op amp based drop in modules- similar to what Mark used in his early gear, which was directly stolen from their use in mixing consoles. You unplug one module, and then plug in a new one if it goes bad. Gets you back up and running when time is money. But he refused, since there is no point being tied to that discrete-based architecture when modern op amps are quieter, faster and cheaper.
