Leroy's 700B
#61
And yes, I did check my test equipment, put it in the system and yes........it comes out the speakers in a very objectionable volume..
#69
Well, the more I mess with the wires around the caps, the worse it gets...
Maybe your noise source is there Lee. Have you used your scope probe as an antenna?
Connect Ground clip alligator clip to probe tip. Move the probe around and look for noisy sources.
#80
Yes, there is a buss bar, and I don't know about the crimp. I just tightened the positive and negative cap screws and dropped the noise level to 4mv from 13 mv.
