Can anyone identify this cartridge?
NeverSatisfied
Houston Texas
#22
This is what the GAS cartridge came off of. I need another TT project like a hole in the head but I love a challenge. I think this one was thrown down a stairwell. The arm is damaged and it would not hold the platter speed. Pulled the motor and found it to be a wet bushing design, the oil was almost rancid. Cleaned it out and replaced with synthetic and adjusted the potentiometers. Now it locks on both speeds. Service manual is worthless, just a parts list, so taking the arm apart is going to be a trial and error exercise. BA158FA4-A72B-4BF1-90FF-1547D4ED14FF.jpeg C9A0849E-457D-4354-9B02-2540CF4BAF8C.jpeg 85A8A480-FECA-47A2-A511-1A645DDEE33C.jpeg
NeverSatisfied
Houston Texas
#29
What's the "sewer" pipe for...
Dust collection system that is in the other room. Those pictures are from when I was building so it doesn’t show the slide gates that allow me to open and close each inlet. I wanted to be able to pull suction from each work station. 86775733-597B-41AC-8F84-A9AE4DD968DA.jpeg 2EB2029E-FF3A-4D09-89E3-CFA00DA96492.jpeg 9FC62CE9-0711-40CC-A2C7-674BCACE27BE.jpeg
NeverSatisfied
Houston Texas
#38
beautiful shop! That pedestal grinder's material collection system is ingenious and inspirational! I assume you built that?
Thanks
I got the idea from a guy who built one similar but he used receiver hitches welded to a 6 inch piece of pipe. I don’t weld very well and wasn’t setup to build it out of steel, so I built it out of wood. It works really well, wish I had taken more pictures when I built it but basically each grinder is mounted to a platform that slides in to a mating slot. You pull the top one out, move the one you want to use into the vacant slot and place the one you removed from the top down into the vacant slot. Not rocket science but I can swap the whole grinder out 10x faster than changing one grinding wheel.
