62vauxhall
- May 14, 2014
- Southwest Kootenays BC
In particular, a replacement for the pilot lamp in a Realistic QA-680 four channel integrated. It's fed from the rail voltage which I measured at ~42 volts.
It's not my amp, I just offered to check it out for someone and fix if possible. None of the parts vendors I've checked so far has anything of similar physical size that uses 40 volts.
