May be from the transformer, they seem to make some buzzing noise.
I don’t know if insulating the bolts reduces or eliminates it completely.
You can eliminate all noise from the transformer except magnetostriction created hum. You can eliminate loose bobbin and loose bolt related noise. Insulating the bolts does help by eliminating eddy current losses in the transformer which manifests as noise energy eventually.
Yes, it’s a “fact of life” regarding transformer hum. Do torroidals do the same? Or to a lesser degree?Almost all transformers hum, make sure the bolts are tight and then turn the volume up
All transformers experience magnetostriction. It is a function of the ferrous core expanding and contracting on a microscopic basis when the magnetic dipoles flip from one direction to the other. Toroids may have slightly better layer to layer bonding than E-I cores but a poorly bonded toroid may also be a victim of flapping laminate layers. And windings are windings. Unless they are properly varnished or cemented into place against the core, they will vibrate too.Yes, it’s a “fact of life” regarding transformer hum. Do torroidals do the same? Or to a lesser degree?
This line of thought was prefect timing, My wife still has most of her hearing left and when I fired up the hot water boiler for our in floor heat a few days ago, she notices a new hum coming from the boiler. I could not hear it until I stuck my ear right down next the control transformer on the boiler. I told her that transformers humming was not that unusual. Here 2 days latter and this topic shows up. I read her few of your responses and she started to believe me. Funny, forty years of marriage, working my whole life with sound equipment, high voltage electricity, and industrial equipment and she needed to hear that transformers can make a humming sound from some other people to believe me.
But you are still wrong![]()
