Technically, not polished, but callendared. (Which may be spelled wrong?)
Callendar rolls are highly polished hard rolls (you cannot eat them) that flatten the coating after it is applied to the tape.
Better manufacturers did it at least twice and their tape is smooth and shiny on the head side. In fact, often shinier on the coated side than the uncoated side.
Sony, TDK and Maxell all did a nice job. Others did too but I haven’t used them all! If I find a new (old) tape I wind it out and have a look. I check for wrinkles and creases but also the surface finish of the tape itself.
Another useful bit- softer abrasives can be more aggressive than hard ones. Stone grinding wheels work best when the wheel is being consumed (wearing) during the grinding. So, those “soft” ferric oxide tapes can be much more aggressive than Cobalt and Chromium formulations due to surface finish.
And no, you don’t ever get back that minute of life you wasted reading that.
