Alpage AL-300
20tajk7
Absurdy, new name of France
A beautiful and amazing deck, back in 1979/80 it was highly praised in the French audiophile magazines.
It's a great performer with cool features such as, 3 ferrite heads with monitoring, dual capstan transport with two motors, independent L/R calibration for bias and level with built-in test tones, the ability record the four tape types, mic and line in can be mixed, pitch control, the detachable panel that can be used as a wired remote control and many more...
More to come soon with the mechanism teardown and restoration and modification of the electronics.
20tajk7
Mechanism disassembly.
The door is damped by a string and a couple of gears.
In this step a lot of parts must be removed, door, switches, brake solenoid...
A large plate of multi-colored spaghetti.
The big play solenoid must be removed to separate the front and back chassis, but the screws are blocked by glue and strongly tightened.
If the deck was "serviced" before you might find screws in very bad shape because that's not common Phillips screws but JIS screws (Japan Industry Standard).
Phillips screwdrivers fits closely, that usually works but for very tightened or glued screws the only way is the JIS screwdriver.
The capstan belt is always turned too goo.
So cleaning the metal parts with acetone, plastic parts with alcohol.
There's two separate clutches for reel drive, the left one with a low torque for playback, the middle one with high torque for ff&rew.
Lubricating the capstan bearings, cleaning and lubricating the levers.
The ff/rew idler arm pressure is adjustable by moving a set spring.
The Kenwood uses a couple gears and an “air brake” to create the soft eject. The arm motion is geared up to spin a “paddle” fast and wind resistance slows progress (against a spring).
I think you could drive a truck over the Kenwood. There’s a square tube frame inside the cabinet. Total nightmare to work on, because nothing unplugs!
vince666
deep south of Italy
I will not be missed! :p
how it is nice to have disassembling pictures sequences and hints for some of those "less easy to handle" models? :)
Thanks, Leo, it if will ever happen to get a AL300, i just know which is the right thread to give a good look at. :cool:
20tajk7
Something that needs attention, the tape path.
Cleaning and lubricating the head base rails, same for the reel table shafts.
New reel table tires.
And new pinch rollers, the left one is hard to adjust with the two nuts.
Test with a cut C120 cassette tape.
Also tested some red rollers made by a friend, he also made the gray reel table tires.
I have found the same (by ear- no fancy equipment) that the Rega drive belts (which I happen to sell) behave the same way.
They need to “run-in” a few hours, perhaps overnight, to give the best representation of their true performance.
20tajk7
Tried this idler kit https://www.ebay.fr/itm/174124313758 and like most of the parts sold on ePay it's a counterfeit...
Left : original AL-300 f/r tire.
Right : a way too hard piece of rubber that doesn't even fits on the pulley...
Same goes for the reel table tires, the rubber is too hard and the surface too slippery even after sanding.
20tajk7
There's a design flaw on the AL-300 that affects playback sound.
Found it when working on one with a very noisy playback.
So I've printed the schematic in high resolution and traced the signal path and power supply lines.
Replaced several capacitors and muting transistors (there's tons of them).
But still got noise and with a 10kHz bump that looks suspicious.
Finally found out the test tone oscillators are constantly turned on !
When removing the power of them, no more noise it's even the best AL-300 I've ever heard !
So I've found a way to modify the circuitry to have the test tone oscillators working only in calibration mode.
After some adjustments of the bias and rec eq that deck is capable of a 20kHz frequency response with metal tape at -20dB.
Can even goes to 30kHz at -25dB with a 1982 TDK MA !
