Any video projector buffs here?
roccus
Maine
You'll blow your ears out kid
#21
Got the video projector all set up, fabbed a ceiling mount for the projector. The audio cable just got here today so I can connect it to my preamp... also need to get a couple pull down window shades to block the light a bit
Australia
#23
Watch the ventilation on the projector or she will overheat. The bulbs make a big bang when they go, unless its LED. They all need cooling space.
roccus
Maine
#25
So I should maybe keep spare bulb on hand? Are they easy to change?
Australia
#26
I burned my fingers on LEDs, too…
I would believe it, they throw a lot of light. I never blew a bulb in traditional projectors, they did lose brightness though. I had a sony one last more than 4000 hours but it had custom cooling. Always went overkill with cooling.
Australia
#27
Easy to change yes, but if you let them blow up glass goes everywhere inside the enclosure, a bit messy. Keep the cooling and ventilation space up and stay within the hour limits of the bulb and you'll be fine. I am not sure how LED's behave when they go, I had the traditional style bulbs, NEC, Sony, Acer, and Viewsonic projectors. Gave in and got a Sony 4k TV recently, sharper picture but not as big screen as a projector can throw.
roccus
Maine
#31
Lamp life, hours of continuous use, expected number of hours before it blows. Doesn’t mean turn it off after an hour!
OK so you saying I should keep a log every time I use it for how long I ran it? Specs say lamp life is 50,000 hours.
#33
Some of the newer units do that for you and will flash a reminder to replace the bulb because the internal clock has logged 50,000 hours. The bulb is the most expensive item in the projector, so they want to sell them.
