Hi Fred
I have a couple of these. Much better than the two piece heat sinks and they have more surface area than the equal length one piece heat sinks. I think these are their best ones. The equal length ones have thicker sections so are stronger against bending.
They phased this in on the latter PL400 Series 2. I have had a couple that I have sold off after using for a mule.
My amps run very cool. But then, they're not rack mounted, they sit in the open on a wood shelve.Same here on my 400 II. @George S. I noticed you have the protective cover snapped back on the outputs...is that advisable on the WOPLs? I would assume they don’t help with airflow on the cans or is that irrelevant? I left mine off
View attachment 50310View attachment 50311.View attachment 50310View attachment 50311
If you play with your amplifiers, as opposed to putting them on a shelf and never touching them, then you want the covers on to prevent a shock. There is 170 VDC, more or less, from one column of output transistors to the next in a PL400. Just reach over the top to dust off the amplifier and your dangling nose pickers will find that voltage. Don't ask me how I know this...is that advisable on the WOPLs?
I thought about that myself. There’s a lot of air space inside the cabinet and we usually rely on convection to keep things at a safe operating temperature, the 700 has two thermal cutoffs (one in the 400). At what point does heat become critical inside the cabinet? There are heatsinks on critical transistors on the driver board, again, relying on convection.I was home alone yesterday as wife was off taking care of some family business. At approximately 1030 I cued up 52 Ramones albums on Foobar2000 and let them play continuous and LOUD while I did some yard work out back and finished up the Hakko units upstairs. The system was cranked, media room windows were open as it was a warm day in Ohio, working outside the music was loud, upstairs working on the Hakkos the music was loud. The meters were swinging up to 1/4 of travel. Nine hours later after not touching the system I felt the amps for heat.
The fins were slightly above room temp, the output covers were warm, the transformers were warmer, and the top cover plate was the warmest. But nothing was hot.
To improve the cooling, if needed, maybe more holes or slots in the top and bottom plates are required. I can envision a steel mesh with a frame.
Perry recommended a nice fan unit some time ago that sits on top of the amp and blows upward. Rather than more air on the fins, I think cabinet ventilation may work better.
But then, if it's rack mounted, choices are limited.
Please don't drill your amplifier, you will just ruin the covers. If you want more airflow, you have to force it through the openings, get a fan! The engineers at PL determined the exact size of the openings to allow natural convection of air based on the temperature differential and the cubic size of the chassis interior.I'm going to look at the top and bottom plates and consider drilling ventilation holes. Getting those Budwig feet under those amps has to have helped.
I can stack all the plates and drill right through. Probably screw them onto a scrap board, mark holes in pencil in a grid pattern, center punch, drill, de-burr, done. Another project!
