These are very high quality units that were made in Japan in the 80s. There are almost always a few on eBay, and from time to time some show up priced reasonable with the now somewhat rare Hakko 802 desoldering gun. The units are now starting to show age, mainly the vacuum pump flapper valves.
Each pump has 2 valve assemblies, this 1 assembly is off a new to me 470B, notice the brittle plastic and flux the pump ingested because the prior owner didn't have the proper filters installed.
So clean the assembly with alcohol and Q-tips, reassemble with a new flapper valve.
This is a 470B, DC motor for the pump.
This is a 470, AC motor for the pump. Same pump, different layout.
And this is the now hard to find 802 gun. Heating elements for it are no longer available, but Hakko has a document online listing a upgrade path using readily available 808 gun heating elements and supporting parts.
Note Hakko made other units like the 471, but it has no internal pump, just a bayonet fitting on the rear for a external pump. Also seen a 472, but don't know about it. 474s popup every now and then. 474s use a unique pencil type desoldering head, and aren't compatible with the guns due to wiring issue.
And now a hint if your going to pursue getting one of these. Some eBay sellers list these as Hako, not Hakko. Last week I scored another sweet looking 470 with a 802 gun for a very, very low price. Yup, listed as a Hako 470. Happy hunting!
