Going to spend some time reading about THD and see if I can gain some insight. Looking at the PL400 manual I see a spec of 210 watts RMS and .25% THD. Does the 1% distortion that laatsch55 quoted come from "overdriving" the amp? If not, then why this 1% distortion figure? Thanks.
The answer is 'it depends'. I test my completed WOPL into an eight ohm passive load, with a 1.4 VRMS 2KHz sine wave connected to the input jack, one channel at a time to determine the balance between each channel. If I connected both channels into dummy loads, that would be a worst case scenario for the power supply. I do that, too. If I hooked the outputs to the four ohm passive dummy load, the power output would go way up, but that doesn't tell me much diagnostically. I look at the output signals on the oscilloscope to check for clipping threshold, usually none. Then I test first one, then both channels musically. Each amp is different, mostly depending on the available voltage provided by the power supply. I have seen PL400's with anywhere between +/- 72VDC to +/- 85VDC. And the PL700 can range from +/- 98VDC to +/- 110VDC.
The last two PL700 amps I did measured well over 1000 Watts peak musical power, which is what you are listening to from your speakers. Depending on the efficiency of your personal eight ohm speakers, you may 'hear' between 500 Watts to 800 Watts. This is stadium level sound, you cannot be in a listening room at those levels, your hearing will be in peril at that sound pressure level.
Lee prefers RMS (Ridiculous Maximum Sound) as the input to his Klipschorns.Peak music power????? Pshaw!!!!
When running the numbers, does anybody pay attention to the line voltage at the AC receptacle? Looking at the manuals, 400/700B has no spec, Series II's are 120 volts.
Line voltage is not all that critical until you get into sags that are pretty serious. The amp all convert the AC to DC and then depending on secondaries make what split supplies that are needed. You can have plus and minus 100Vdc supplies in amps and the higher voltage is required due to ohms law.
I once said how do these Auto amps get such high power from out of 12Vdc? Well what they do is trade current for voltage and some elaborate heat sinked supplies get some higher voltage even in car amps that are even before and Audio transistors see the heat sink. They are like switching power supplies but up the voltage in trade for higher currents then with the higher voltage and 4 ohm speakers the power rating can be more than 20 watts per channel. There are voltage stabilizing transformers that you can buy if the voltage bothers you but this is all being a bit too picky.
It kind of reminds me of the Church installed back auditorium amp system that was a 5000 watt rating when it was supplied from one 20 Amp wall circuit and it was not 220Vac. Does anyone see the problem with that for the full power? This is what happens when you hire idiots when there are Radio Engineers around that could have done the job correctly.
