62vauxhall
 - May 14, 2014
 - Southwest Kootenays BC
I'd like to get hold of some too.  It smells wonderful!
			Years ago we had a hot tank with tri- Ethal clorithene about 4’ x6’ x4’ deep.Remember carbon-tetra-chloride?? Good solvent, good carcinogen...
I remember the same kind in our local machine shops round here. I have no idea how they clean engines now. Too old to consider building one now.Years ago we had a hot tank with tri- Ethal clorithene about 4’ x6’ x4’ deep.
You put in an engine block and after an overnight stay it came out stripped of everything. The tank was heated to a vapor point of the liquid.
Running around the top off the tank were three 1” condensing pipes to cool the contents to a liquid And prevent gassing all of us. I guess I am lucky to have lived this long after such a dangerous work place.
That is more like what they had here, a caustic. And yep, same here Brad as far as projects...just small stuff here...electronics though.This setup was way different that a hot tank which are just heated caustic, still dangerous. The tri ethal setup was band years ago
Methanol (CH3OH) is corrosive to aluminum, eats rubber and some plastics. So I am going to use straight ethanol (ethyl alcohol, or grain alcohol) now for electronics (WOPL Control Board) cleaning. Do they sell Everclear in Wyoming?Pretty familiar with methanol.
I've only seen the 70% Equate here in our Florida Walmarts, but Amazon has a 99% IPA 16 oz. for $3.05. I wonder if that would be more better?Safest is isopropyl alcohol 91% that they sell at Walmart
