Tall order, sounds like a pain
Just got a request for 4 "Rack Mount" 700 II WOPL's with Silver face plates.... Damn, the Chassis' and face plates have the dimples in them so finding 4 will be near impossible (Although I just sold 2 of them a couple weeks ago). See Joe? We should have made the series II face plates (still wouldn't have the rack mount dimples to mate the Chassis with). I don't think I can pull this off especially sine there a no Rack Mount II's out there ready to be WOPL'd....
Trust me, I've done dozens of these rack mounts... Didn't you know??? Man, you guys gotta get out more.... Let me look if I got some pics.....
For those that have not seen the rack mount 700 Series II's (from the inside anyway), here is the inside pic... It fits together like Jack and Jill so to speak....
None of the PL amps (that I have seen) are really set up to conform to proper EIA-310 rack spacing. I do rack mount equipment design for a living and no PL amp I have ever seen has conformed. Perhaps they had such but it is not the standard fare. I rarely see any audio equipment set up properly for NEMA rack mount (save for my Tascam 3U deck which has the proper NEMA slot spacing). Most rack mount audio that I see is more for eye candy than practical rack mount use.
It did seem like the chassis' were a bit thicker but I never measured. Maybe I'll measure one of these days..... Naw, who cares really???
Yeah, the face plate was TERRIBLE, and the chassis was dimpled unless I took a hammer to it..... Rather use one of yours.
What is the center to center distance on the 2 dimpled holes Perry? Is it the 5" dimension that they used for their handles?
I like your assembly fixture idea Perry. I have a lot of assembly jigs but not one for that.
Yep, that old chassis cut down to just the back plane portion is great for wiring up those Back plane Boards of yours. Smartest thing I ever made. Just used it for the Jolly Green BP's.
grapplesaw
Vancouver
That face plate was not a factory preped rack mout. The slots in the chassis are stock on most series ll
I have a 400 and 700 factory plate and will post tomorrow with dimentions.
oldphaser
If my memory serves me correct..........
Most Phase Linear series two consumer products had a front panel with rounded corners. As an option, they were available with a "rack front panel" which had square corners. I am not sure if they had to be ordered with the optional rack front panel at the time of purchase or the front panel could be ordered later. The rack front panels do show up on parts lists for most of the series two products. So I am assuming that they could be ordered at a later date. Some of these rack mount front panels may have even had factory machined slots to properly mount into a EIA rack. It has been a decade since I last owned or serviced any of the consumer rack mount products. I can't recall if they ever had any countersunk/dimpled front panels/chassis. I don't recall seeing any.
The Phase Linear 700 series two amps with countersunk front panels and dimpled chassis more than likely came later in production. Perhaps around January 1981 when Phase Linear went to a fully complementary output and began introducing their pro series (black front panel) products. The rack front panel does not show up on the original 700 series two parts list. It does show up on the later 700 series two parts list when they went to a fully complementary output and used NPN and PNP output transistors (i.e. TP9054/DB15025 and NEC 2SD555/2SB600). Obviously, with the dimpled chassis a dimpled (countersunk) front panel would have come along with it and would have had to be specified at the time of purchase. I have owned and serviced a fair number of these amps.
Dean N. told me years ago who the employee was that suggest the dimpled front panel and chassis but I have long forgot. It might have been Dean himself. The purpose of this countersunk/dimpled front panel/chassis was to be able to flush mount it into a rack.
Ed
