WOPL update for PL400
I thought duct tape was for keeping things from moving. Use a hammer when things are stuck.
Were the transistor covers for the PL400 just friction fit? ie, just slip them on and slip them off?
They snap on under spring pressure created by the shape of the cover. It has a minor bend in the middle of the cover which acts as a spring to expand the small grab bends at each end of the cover. It snaps into a machined groove you can see at the top and bottom of your heatsinks.
If you are handy with a pair of tin snips, you should be able to fabricate covers fairly quickly using aluminum roof flashing rectangles (Home Depot). They won't be anodized unless you can find anodized rectangles (they do exist) but they will be functional. Just don't short unanodized covers (anodize coating is an insulator) to the transistors or you will be blowing fuses.
I don't know I'd trust the anodize to provide insulation... It's REALLY thin!
Maybe brush some tool-dip or liquid electrical tape (probably the same stuff?) on the side that may/will contact the transistor?
Jim, I don't think the cover actually touches the output transistor. There is some clearance between the cover and the top of the transistor.
I now see the groove the cover fits in. Was the cover anodized aluminum? Aluminum is so soft and not particularly springy. If someone removed them, I could see where it would be easy to deform them enough that getting them to properly fit when trying to reinstall.
The covers use air space as the primary insulator, the anodize is secondary and also for appearance.
Thin Aluminum is quite springy and does quite an effective job, the spring stresses in this application stay within the elastic deformation range and get no where near the plastic deformation stress levels.
They are not that easy to deform
No, not aluminum, a thin sheet metal that was fairly stiff. With a bend on the ends to form an 1/8" clip to go in the groove, then it went out from the backwall enough to gain lenght enough to unclip them when pushed back towards the backwall.
Doesn't feel like aluminum to me Joe, never tried a magnet on em though...
God, I have a box of those in the garage....maybe even the 2 large for a 400....
Blue Crab, I'll check tonight...
They are 0.031" aluminum, 5052-H32 with anodize. Not magnetic.
Thanks.
Yet another question. What does 0dB on the VU meters represent - reference power out? 200 watts into 8 ohms for the PL400?
In theory yes, but I don't think it does. Ed had this figured out one time. I think it's more like 150 to 160 watts.. it was suggested that the factory liked the figure below rated output at 0 db thinking it would deter more turning to the right...
Lo and behold...
They never envisioned the people on this forum...
Correct Dr.......how could they.....
Trying to understand the small numbers below dB numbers - which show 100 at 0dB, 80 at -1.5dB, 60 at -4.5dB. Doesn’t seem to match wattage unless +3dB is 200 watts, but then 50 should be at -3dB.
