That’s pretty fast! And it sounds like he did a good job on it too.
Enjoy it!
Jim, This is the info from the service invoice; all parts and labor. This is direct from the invoice.
Service Performed: Full inspection. Repaired bent tuning flywheel shaft. Replaced all electrolytic capacitors (except main filter capacitors) on all boards with high-frequency low ESR, high temperature parts. Overhauled power supply. Repaired old/stressed/defective solder on various PC boards. Replaced defective transistor in right channel power amplifier. Set bias and offset. Repaired and renewed output relay contacts. Repaired and renewed surge-relay contacts. Cleaned and treated all switches and controls. Performed full FM and stereo FM MPX alignment. Performed full AM alignment. Calibrated output power meters. Measured output power and distortion. Performed "beauty-maker" cosmetic treatment, including chassis and behind the glass cleaning and treatment. Replaced broken union nut on faceplate assembly. Full audition and expert sonic evaluation, PASSED. All functions OK.
Parts:
69 Electrolytic capacitor
02 2SD712 transistor
01 2SB682 transistor
06 2.5A 1000V diode
01 2SA850 transistor
01 2SC945 transistor
01 2SC1735 transistor
01 2SC1775 transistor
03 1A 250V fuse
01 ABN-021 boss/union nut
Labor: 8.0 hours
Shipping: $140.00. This price included my portion of the cost. This receiver traveled about 2,000 miles round-trip.
I didn't include PS's labor or parts cost as his cost probably differs between machines. This receiver was repaired in August 2011.
Ron
