- Jan 14, 2011
- Gillette, Wyo.
I have decided that there is no use keeping something I am not using.
1---Pioneer "The Rack" 2 wide, includes the turntable shelf and cabinet doors for the rack below the turntable shelf .
2---1--Spec 1 pre-amp. Restored to Echowars's specs by me in 2012, cosmetics, Immaculate.
3---2--Pioneer Spec 2's, one restored to Echowars' specs by me in 2012, 2nd one untouched with less than 100 hrs on it. Cosmetics, Immaculate.
4---1---RTU-11 Tape transport, Not many hours on it either. Comes with both 2022 and 4044 head blocs 3 spare NOS heads ( 1--4 channel playback, 2---2 channel playback), 1--JT-211 remote control. Beauty rings on tape transport control switches are off due to rubber retaining rings rotten as is the counter belt. Cosmetics-immaculate.
5---2--TAU-11 tape amplifier units. Includes both cables to hook to the TAU. Cosmetics-immaculate.
6---1--TX-9500 II Tuner. Low hours as the Spec 2, and RTU. Cosmetics-immaculate.
7---1--TX- 8500 II Tuner. Works fine, not as low houred as the rest. Cosmetics-Immaculate.
8---2--SG-9500's, One, low houred, the other bought new by me in 1975, works fine, cosmetics--Immaculate.
9---1--CT-F9191, low houred as the Spec 2, TAU, and 9500 II, cosmetics-Immaculate.
10--1--RG-2--Ebay item bought years ago and has the upgraded selector and on/off switches. Scratches on upper surface of faceplate from stacking.
11--1---SR-303, obtained from a PAC member, slight scratch on faceplate.
12--1---DT-500 Timer--, cosmetics--Immaculate.
13--1---D-23 4 way electronic crossover--e-bay item, works good. Slight dinging on top of faceplate due to stacking. Slight discoloration of level knobs, haven't tried to clean them up yet.
14--1---Teac --AN-300 4 track noise reduction unit.
All 10" and 7" tapes go too.. a spare rack tray, some rack blanks, and a rack slide drawer..
Price----------7500.00 for all.
Shipping---It goes without saying that individually packing and shipping this much stuff is going to cost a LOT. Pick up is preferred, HOWEVER, if you insist on shipping contact me and we will start the negotiating process.
I realize a lot of this size will not be a short and done deal. If you require me to wait 6-9 months before you can be here to pick it up, a small deposit will hold it.
