PhilcoFord
- Oct 24, 2019
Hi, My name is Bob Moore and got the gift of retirement 3 years ago, and sorting through lots of old projects, usually too many at once. Dad was a Philco guy all the time I knew him and left way to soon leaving me with a yearning for all sorts of old electro mechnical stuff and I have collected pretty well.
Just pulled this gnarly old 700 out of the back closet as I am also working on a couple other amps. Started building popular electronics SWTPC amps back in the 60's and 70's then graduated to other stuff as it became available.
The 700 had a blown main fuse, but found out one channel is ok by leaving the other fuses out, so now wondering how many bad outputs etc, never worked on an amp quite like it! I can run it on a lightbulb ballast and wondering if probing all the emitter resistors is a way to start or if I should try and start unplugging them and start testing out of circuit??? and what is ON Semi replacement recommended? Just got a set of MJ15003/4's for the Marantz 15 I have apart but these NPN's seem to have a higher rating with the 100V rails . . .
Thx for the add!
-Bob
Thx for the add!
-Bob
