Al K's Extreeeeeeeeeeeeeeeeeeeeeeeeeeeme Slope Crossovers!!!
#41
I'm assuming you've installed these Lee, correct? Am guessing 48 dB/ octave?
Were they quite an improvement for your K's?
I was wrong Scott, these are 96 db/oct..
I borrowed them to Stephen in Phoenix.....not getting them back, so I called Al Monday, another set will be here in 6 weeks....
#49
The cable is too big to just run it up the back of the speaker like the old #14 THHN.
So I drilled a hole the same size as the cable jacket, installed, the put the jacket termination back on....kinda like a cheap asscablegrip .
BlazeES
I never took those apart before. So you're saying you can easily disconnect the main conductor run from the hub/+&- Y end?
#51
Yep, you ever had an old school hydraulic hose connection apart?? Same thing actually...
#53
There are two adjustments to be made.
A tweeter attenuator setting and a mid horn attenuator. They are there due to the different efficiencies of selected drivers.
Range on the tweeter is zero to minus 9 db
Range on the mid horn is minus 1to minus 18db.
My initial setting will be minus 5 on the tweet and minus 10 on the mid.
#59
DAYAMMMMMMMMMMMMMMMMMMM!!!!!!!!!!!!!!!!!!!!!!
I can get loud without the mids breaking up !!!!
