The circled diodes 1N4148s D301 (310) and D304 (307) are missing as well as diodes labeled R 302 (309) and R 303 (308) and D305 and D306. I think THOSE were mods done by the GAS folks, they literally pulled every diode off that board except the 28V zener across the opamp. Also curiously, R329 2.2K is missing and in its place are (2) 39K resistors from pin 5/3 and pin 8 of the opamp to ground. But that circuit is only part of the servo loop.I wonder if that was part of the mods from the folks with the sticker on the front??
GAS 112 is cross referenced to NPN 2N5088 in the spec/schematic, on the board they are 2N4401 and 2N5210.What were the GAS 112 trannies??
Mark, remember the Longfellow method of matching?
The caps are needed because there may be a tiny DC voltage on the comp-diff pairs bases. Yes, the DC servo should keep DC close to zero, but a slight DC voltage will cause current to flow through the phono cartridge. It could ruin an MC, but wouldn't harm an MM. The change from 68uf to 100uf may have been to accommodate MC without rolloff.
I should remember something about Longfellow. He said:
Music is the universal language of mankind.
and
In character, in manner, in style, in all things, the supreme excellence is simplicity.
But you will have to refresh my memory on the method of matching, and possibly educate some of the newer forum members.
Agreed on the need for caps on the inputs, but I had never seen electrolytics used for this purpose. This amp is not rated for a MC cartridge, but I get your point, those things are sensitive and delicate. I am going to use 68uf Tantalum capacitors (four per channel), which of course are non-polarized. I don't have a turntable to test the phono section. I could send the pre-amp to my brother who has a nice Pioneer turntable with a Shure V15 Type IV cartridge and a newish needle.
I would be inclined to use something like this instead of a polarized cap of any sort. You want low leakage and electrolytic types have leakage.
810-FK11X5R0J686M
Or
810-FG20X5R0J107MRT6
