If it were mine, I'd install 100uf 25 volt NP non-polar electrolytics. Tantalums are polarized, and are usually low voltage. What is needed here is low distortion, and any cap with a polarized electrolyte is going to make distortion. Adding a 0.1 uf poly cap in parallel won't hurt. Back when this preamp was popular, the rage was to run MC cartridges directly into 47k ohm phono stages. You had to turn them up, and the preamp had to be dead quiet, but better sound was usually obtained because one less device was in the signal path. The only thing that beat no head amp was a really excellent MC transformer.
