oldphaser
- Sep 8, 2012
Here are some links to documents concerning the different types of resistors and resistor noise.
Basics of Linear Fixed Resistors Vishay Application Note Document Number 28771, Revision 11-Nov-08
Resistors by R.A. Fairs Wireless World Oct 1975 pgs 487-492
Build the J-Can To Measure Resistor Noise by Joe Geller Nuts & Volts July 2007 pgs 54-62
Part of MIL-STD-202G:
http://carlsonmfg.com/resources/military-standards-1/2290-mil-std-202g-method-308-pdf-1/file
NOTE: The current standard is MIL-STD-202H. However there seems to be a problem with their website.
MIL-STD-202H Test Method Standard Electronic And Electrical Component Parts
Quan-Tech 315C Resistor Noise Test Set Brochure
Measuring and Evaluating Excess Noise In Resistors by Brewster LaMacchia, Bradford Swanson AES Convention 145 October 2018 eBrief 486
Resistor Noise – the experiment and the results
SPECIAL ISSUE: FIXED RESISTORS Electronics World Apr 1965
Noise in Precision Film Resistors by P.D. Smith Texas Instruments August 1961
Resistor Current Noise Measurements by Frank Seifert April 14, 2009
Measurement of 1/f Noise in Carbon Composition and Thick Film Resistors by Patrick Barry and Steven Errede
IEC 60195 Method of measurement of current noise generated in fixed resistors:
https://global.ihs.com/doc_detail.cfm?document_name=IEC 60195&item_s_key=00132181
Designing For Ultra-Low THD+N (Part 2) Resistors and Capacitors by Bruce Hofer AudiXpress Dec 2013 pgs 18-23
I also have some links to even more technical articles that perhaps only an engineer could understand.
Ed
Ed
