punchback
- Jan 8, 2019
First time posting in the Phoenix forums due to my recent acquisition. I've been jonesing for a Phase Linear for a long time. I mainly look on CL and I don't see them too often in the Cincinnati area. One popped up on CL that seemed a good price for an operational unit. So... I’m the proud owner of a new “old” PL400. It seems that it is an early model with a 4 fin heat sink configuration. It also has fuse type lamp to illuminate the meters from the top. This meter illumination apparently prevent me from using the White Oak Audio LED upgrade. Let me know if there is a way to make it work with my PL400. It is operational and has the stock (12pcs) PL909 and (4 pcs) SJ2741? The front panel is rough and has some sort of clear splatter on it. My wild ass guess is the splatter might be floor wax??
I’m looking for suggestions as to what is a must do upgrade. So far the following is what I plan. Let me know if I’m missing anything.
Alan
- It seems that most everyone upgrades the power rail caps to ~15,000uf @ 100V. I know that WOA offers a kit where they stack 2 caps to accomplish that but I’m not sure they'd work with the clamps that hold the caps in place. I’m kind of looking at the following caps from Mouser. I’m not sure exactly what to look for in a cap such as this… Would it be better to get a 105°C cap (80-ALS80A163KF100) or a cap with a higher ripple current and little lower ESR (871-B41458B9159M000)? Both are almost the same size as the currently installed stock capacitor. Or is there some other reason to get one over the other?
- If I upgrade the caps I’ve read where that puts a strain on the bridge with all of the inrush current when it’s turned on. Should I upgrade the bridge? The current bridge is a 200V 30A (MDA990-3) with a date code from 1971. The next step up in current rating at Mouser is only 35A and the next step from that is 50A (905-KBPC5006T)
- It goes without saying that I’ll be installing the Watts Abundant speaker protection board.
- The front face plate is a little rough. I’ll be attempting to clean it up. I see where someone on eBay sells a reproduction. Has anyone used this reproduction and been happy?
- Eventually I’d like to install the WOA control board.
Alan
