A brief recap....after the initial repair, when putting it on the scope and AP, when I turned the generators on I had voltage set on 2.36 , from the last max out I ran in the killowatt range on Stephens 700. Blew the minus and plus rail fuses. Positive was obviously blown, minus looked good, did NOT check with ohm meter. So I never had a scope reading with minus rail voltage, but did have minus rail voltage on the unfused check points. DUH....
So after, getting both the minus rail voltage AND pico fuse fixed , looked good on the scope....
back on the horns.....sounded like shit again. The Acurus pre required exercising the balance and input select pots to get sounding right.....but it is once again sounding like a WOPL!!
Guys ----DON"T ever take anything for granted----you'll look like a fool...
