Started to Cascade the Back Planes, using the heavy stuff from Dennis. I expect the other set of Back Planes from Joe here soon. I have to adjust a couple caps and resistors on the PL-36 board from Nick and this will start to come together. Still have not figured out what I'm going to house this stuff in.
Hey Joe, if you read this, I was wondering what happens when you mix bulk caps in the power supply section. Can you use a 15,000uf 160V cap with a 40,000uf 200V cap? I have both and never thought about how it would work. I thought I'd check instead of just trying it. Do they both need to be the same? I'll get my order together either way. I don't know how it would affect the rails with a 40000 on one side and a 16000 on the other.. Probably doesn't sound like "SOUND" engineering. Lee, jump in here anywhere, I know you have "Experimented" a time or two.
HUH????
