My PL700B by Marco
marcok
Milan Italy
I have some questions about PL 700B transistors , because after a more
in depth diagnosis these transistor are K.O. (one channel only )
- 2N 1304 ( is 2N 440 A a good replacement ?)
- 2N 1305 ( already found )
- Rca 40327 ( is 2N 3440 a good replacement ? )
- 2N 3403 ( is it possible to re-use the heatsink ? )
- RCA 410 ( is MJ 1800 a good replacemement ? )
For power transistors no problem , because I have a complete set ( 20 )
of XPL 909 marked with blue ink like original ( 5 K.O )
Anyway no problem to find everything in ebay.com
Replacement transistors are available in Italy and UK .
Thank you in advance and ciao
Marco
P.S: a little surprise : Phase Linear mounted a 10 A fuse instead of 5A on AC mains .
Unbelievable .
oldphaser
Marco
Unbelievable .
Marco,
The 2N3440 will work as a replacement for the 40327.
Other people on this forum have been re-using the 2N3403 heat-sink.
Although Phase Linear used the MJ1800's as driver transistors for a short period of time, I do not know how "good" or reliable it was and why they stopped using it.
NOTE: There is a fellow on ebay in the U.S. selling RCA410's for less than $2.50 each.
https://www.ebay.it/itm/RCA410-RCA-...578831?hash=item51d6a6604f:g:gaEAAOSwDNdV3kYX
Since you are in Italy and the line voltage should be around 230V, I would expect the AC (line supply) fuses to be 5A not 10A (for 120V use).
Ed
marcok
Milan Italy
Possible , because everything is possible ,
but I know the history of this unit .
40 years ago my hifi guru sold it to the previous owner factory made .
The reason of this fault is that this guy lately used this unit in the
bathroom every morning for 10 minutes during shaving .
Humidity and condensation and after obviously smoke !
My hifi guru worked in a shop that was the official retailer for Milan zone
for PL , Altec, Klipsch and other makes and furthermore
the lab of this shop was the PL official repair center for Italy .
Any way they are things that happen .
Now I request infos about transistors to do the best choice .
Ciao
Marco
marcok
Milan Italy
Thank you Ed .
Infact I and my hifi guru
were surprised to find a 10A fuse .
It was only a consideration .
Any way the story is always the same :
check everything before power on.
Ciao
Marco
Bradrock
Alton Mo.
---I run with Scissors
Hey Marco; What do you think of the new F1 rollbars? I do not understand the post right in front of face??
And Hamilton does not alway's win!
marcok
Milan Italy
Simply ugly .The name of this rollbar is Halo .The F1 circus is an insane world .
I hope now the new American owners of the Circus will change the rules in the right way . ( 2021 ).
Ciao
Marco
Bradrock
Alton Mo.
Ciao
Marco
Thank you! I did not want to say ugly & possibly offend a real F1 fan! I hope they go back to a REAL pace car! Virtual pace car? Virtual rules? virtual judges? virtual winner!?? What?
marcok
Milan Italy
I don't know how they measure the delay between two cars in case of safety car .
There is a sensor on the front wheel ( I don't remenber if left or right ) and the measurement has made
between two dedicated rows along the circuit .Why not on the rear wheel ?
Simple there is the traction control .
Last year there was the Twing to "improve " the aerodynamics . It looked like a VHF dipole .
I have no words . Too much SW .
Fortunately there are " toys" just like PL 700B equipped with germanium transinstor !
No SW , no uP but it sounds !
Ciao
Marco
marcok
Milan Italy
Here are the handles and the knobs polished by the son in law of my hifi guru.
Ciao
Marco
marcok
Milan Italy
The son in law of my hifi guru works in a company that works alu and so....
After I will add dots ( decals ) on the knobs , because this type
has no dots ( original ) . They look the same as PL 700 .
Ciao
Marco
marcok
Milan Italy
Just finished to restore front panel :
- removed little scratches on alu front panel with steel wool # 0000 ( generally used to restore old forniture )
- cleaned front panel with ammonia
- retouched plastic mask with with flat black on the the rear side by a microbrush
-replace blue film with " gel " film like original
-cleaned VUs ( inside / outside ) with lcd screen cleaner
-spray painted VU frames .
-spray painted top cover with alu primer and matt black
-ordered in UK 2N 1304 , 2N 1305 and 2N 3403 ( brand TI )
Now I have to wait for 1 week to receive transistors .
Ciao
Marco
PS : It looks like new .
marcok
Milan Italy
Just finished !
Now I have only to clean the finns .
The unit is already at my father's home and tomorrow I will connect it to Allison One .
Now I'm too tired to go on !
Ciao
Marco
marcok
Milan Italy
Thank you !
But many thanks to my hi fi guru for electrical repair and to
his son in law for polishing handles and knobs .
Curiosities found during the job :
-Caps size looks different
-Handles are made in zamak and not in alu
-Knobs screws are used as a reference point for level pots ( from You Tube )
So decals are useless .
True ?
Ciao
Marco
marcok
Milan Italy
It works and the sound is great by definition !
Since my father doesn't want to sell PL 700 and he would give to my brother ,
I need a suggestion for a good preamp for it .
No PL4000 : I prefer Sing Sing instead restoring an other one .
Ciao
Marco
PS: we are PL fanatic family .
Nicely-done, Marco. I appreciate the extra work done to refinish the cosmetics to make it look as good as it sounds. And I like to hear of a vintage component with a story and some past history about it from the previous owner.
