- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
Cerwin Vega A-2200
200wpc @ 8 ohms
375wpc @ 4 ohms
I find it interesting that this amp almost doubles down. I had it set up in the garage using a APT Holman preamp, the amp is driving my CV E-712's out there. I moved it into the house using the Perreaux SA3 and driving the D9's. I noticed the bass was not tight at all and seemed to break up as volume goes up. Amp sounds muddy in the house whereas it did not seem to in the garage
Anyway, I would like this brought up to todays specs so I will be looking into replacing the big power caps also and maybe other things that could be out of spec. I was fooled by garage listening into thinking it sounded somewhat similar to the big Clair but even Debbie noticed the huge difference in SQ
If you can't see the numbers in the pic below, I will take the screen off again and write them down
EDIT: I see it looks blurry so I will post what they say
200wpc @ 8 ohms
375wpc @ 4 ohms
