Hey ScoutII, you need to play with them ( I know, it's not easy with 8' 100lb monoliths
) , while you may like the sound toe'd in slightly...I have my Summits the same way. But, not like others and the manual says to do, it depends on your room and what is behind them!! I'll give you some tips based on recorded music that I'll assume you have. If ya don't, you should be shot and quartered
J/K
Pink Floyd ~ 'Wish You Were Here', title track, David should sound like he is sitting on a stool about 3' from the floor, dead center with his right hand finger picks, his left hand fret work slightly towards the right speaker, then moving to center when he slides down the fret.
Pink Floyd ~ 'The Wall', disc two , starting with track 9 'Run Like Hell' thru track 12 ' The Trial' , you should have wonderful center images with all kinds of batshit crazy stuff sounding from beyond where your side walls are, this what a sound stage should sound like when set up properly, the walls dissolve!
Get the center image right and have at a least 6' from the side walls on both and the magic will reveal things that make you say
Day'um!!
