Here in this forum DCP protection is strongly recommended , but
I don't exactly understand the real advantages .
a ) most of preamps have a resistor and a cap at output stage ( 600 / 820 Ohm and 4,7 / 6,8 uF in series )
so no DC at the input of the Power Amp
b ) in case you have Pl 700 you can select normal / DC and so it' s possible to insert another protection .
I use normal position to drive Allison One with 3,15 amp fuses in series .
c ) in case you have Pl 400 you can simply insert ( if you want ) a 6,8 uF cap at the input .
In my case I have no problem to drive Infinity RSIII , because they have two big caps at the input .
This " strange crossover " creates a thump at power up , but it' s very easy to fix this issue , using
a 510 Ohm 5 W resistor connected between + and - of the speakers .
Look at the last page of PL service manual .
So are there other reasons to use DCP for domestic application ?
A curiosity : why PL 200 is equipped with DCP and 400 and 700 have no this circuit ?
Ciao
Marco
