Thanks guys I will have a look see... thing that is puzzling me is why did it just start doing this now and not from day 1? I did not run the frequency test when I did the build I did the dmb with a veriac hookup.... as some of you who followed my build will recall I hooked up to the wrong leg of the rectifier but once I got it on the right side of it on power up the relay on the DCP would kick in at about 60V
Right now my C-1 preamp is also down I did what is called a BillD mod on it. The first stage of the mod is changing all the caps which I did and it worked out great I got good clean sound and it improved my bass response I was very please with the results I then decided to go onto stage 2 of the mod where you replace a few key opamps. The replacement opamps are surface mount so you need to get adapters called browndogs, these adapters have solder pads on top to mount the surface mount opamps to and the bottom of the adapters have have pins that align up perfectly with the original opamp pin holes on the PC board.
While I waited the 4 or 5 days for the new opamps to get here I was really enjoying the new amp and the C-1 everything was working perfect. When the opamps got here I out them in paying close attention to make sure I got pin 1 to go where pin 1 was supposed to go on both the surface mount opamps and then the adapters to the PC board. When I connected the C-1 to the 400 I was horrified as all I got was some static, popping, and squealing, the meters on the 400 were jumping all over the place something was really wrong with the adition of the new opamps.
I pulled the new opamps out and put the originals back in but still the same thing I must have blown something else in the C-1. I have been in contact with people over on the Carver forum about this issue they asked for pics of the new opamps mounted on the browndogs which I put up for them they agree I did build them right but mentioned there may be a problem with the new run of adapters. So I ended up connecting the pioneer SX 939 back to the 400 for the preamp as I was using it before I got the C-1. But this problem with the relay started after I had connected the screwed up C-1 to the amp and is why I was wondering if the preamp could send a DC voltage through the amp.
So now I am sitting here with my C-1 down and my amp going down it sucks to be me right now after all my hard work and investment to be where I am now.. lesson here quit while your ahead if I had stopped after the stage one mod on the C-1 everything would probably be good now but I stuck my neck out and went for it all now it is costing me
