The original wiring for the power caps has 2 eye terminals to connect them the top one go to the buss and the bottom eye terminals have 3 wires connected to them right now one wire goes to the rectifier then their is an eye terminal with 2 wires crimped in it one wire goes the fuse holders and looks like the other wire went to the stock backplanes... do I need this extra wire that went to the stock backplanes any more or do I eliminate this wire as it looks like the wopl boards get their power through the fused and unfused wires. So another words those bottom terminals on the caps should only have 2 wires going to them from the fuse holders and the rectifier right?
hmm I am seeing wires the go from 11L and 12L to the caps from the pl14 board right now I have the unfused wires on the back planes going to the fuse holder tips...
OK.. now back to our regularly scheduled program lol... so to recap the unfused wires going from backplanes to fuse tips is correct? and the only other 2 wires that go to the caps will be from the pl14 board right?
pretty sweet only took me 45 min to get my first output transistor to line up and plug in lol... think I'm going to have to reschedule my retirement to a later date!
found a little trick only took me less than 5 min to put the other 3 in... put the screws in the transistor then carefully lower the transistor into the holes the screws help guide the pins to where they need to be and transistor almost just drops right into the sockets
Well far as I can tell Geri is ready for her first electrified sex session... just pulled my dim bulb tester down it only has 100w bulb will that be ok? And my variac is rated at 7.5 amp but it was made in the 50's and everything back then was underrated....
