Ron's 400, Previously Owned by Some Guy in New Hampshire
#33
That's why I buy 10 of each at a time. Bare boards only, then Mouser the components.......
So back to this thing...
I basically took it apart, cleaned it inside and out, replaced some missing hardware, replaced the mangled heat sinks, cleaned the outputs and installed sil pads, touched up a couple suspect solder joints and put her back together for testing.
I do still plan to install a DCP and new bulk caps.
Anyway, I fired it up this evening for the 1st time. Today's question concerns dc offset. At startup, the left channel had over 75 mV and the right only had around 5 mV. After running idle for 10-15 minutes, the left side has gone down to around 15 mV. So is this anything to be concerned about?
Also, I wanted to check the bias. This has 4 adjustment pots (early style board). Anybody care to enlighten me on the procedure on this board?
Dan
So I took a few liberties with the hardware. The bolts are chrome since the originals were long gone. I disn't care for the knobs so I used these that were from a guitar pedal I think. Faceplate cleaned up nice, but I left the stock number sticker on the upper left corner.
#38
Dan
Need a pic of the board....
