As said below, you'll trash most of those innards anyway. The biggest difference (other than the fins) is how the power supply caps. and bridge rectifier are mounted. The caps are mounted with with those clamps that hold them to the side of the case instead of the strap that holds them to the aluminum cap that fits over the top of the transformer. White Oak should be able to steer you to the proper caps since their "basic" 400 cap upgrade won't mount with those side mounted clamps. Not a huge deal as long as those caps are available. Probably going to boil down to a non-issue.
I've got a 4 fin and an 8 fin that both need upgrades and I figure I'll start on the 4 fin as a learning experience. Then I can move on to the 8 fin and give that 4 fin to my brother. Then it's the 700B!
Welcome to the mad house.... you'll love it here!!!
