Phase Linear 400 Series Two New Black Lasered Faceplate
fitz43
Lower Mainland, BC, Canada
#81
Logic would suggest that if Clair had racks of amps that they would be 700's , just for the fact that when one went down they could switch over on the fly. Perhaps they had some super efficient horn arrays that only required a 400.......maybe it didn't work out?? Who knows....perhaps an old Clair hand will stumble accross this thread and enlighten us all some day......
Until then.........be cool....
from here:
http://www.prosoundweb.com/article/...t_las_sports_arena_with_bruce_springsteen/P4/
Power Amplification
Amplification for the house system comprises Phase Linear 700 amps built to Clair Brothers’ specifications.
The grounding and output stabilizing network was modified to make the output “electronically a little beefier,†and the chassis fabricated from steel rather than aluminum.
According to Jackson, “The basic ‘Phase’ has a lame output network. If it goes, it makes the amp tend towards oscillation, which is compounded by the inter-amplifier capacitance of the long feeds we run up to the speakers. The long cable runs also reduce the damping factor by adding unwanted impedance to the amplifier.â€
Clair Brothers used to hang the amplifier racks with the speakers, but if an amp or speaker blew during a show there was no way to re-patch it until after the performance. Instead, it was decided to run heavier (12-gauge) cable, and keep the amplifiers on the ground.
There are 14 amplifier racks with four Phase Linears in each. The top amp in the rack drives the highs in four cabinets (two cabinets per side); the second amp down the mids in four cabinets; and the third and bottom amp the bass (one cabinet per side). The two top amps are loaded to about 350 watts into 8 ohms per side, while the bass amps are rated at about 700 watts into 4 ohms per side. All amps are transformer isolated from the console.
clair.jpg Look like 700B used here
stuwee
Deep in the Sonoran Desert SW
#82
Thanks for that post fitz!! I saw Yes around that time and never noticed the amps up there! Waaay cool!
This PL stuff is for the birds...sticking with my SAE gear for now :happy2:
#84
Whether it's counterfeit or not is still open for debate. Because Ed hasn't seen or heard of them does not mean they don't exist. Phase was notorious for lousy documentation. Tony says he copied an existing plate. Is it up to him to verify the unverifiable?? I mean Christ, if THE PL GURU can't say for sure , then I would say, back to your corners until further developments
Yes. Shame but that amp never existed. Bought the only one left. Hope this puts an end to the issue so we can move on to having our fun.
Settles it for me until proven otherwise
#85
Clair is still in business
. I called their engineering department and left a message for a Josh Thad, he was in a meeting. I'm gonna ask about a Clair 400 and for a list of Clair 700 serial numbers...will keep youse posted....
