OK, quiz time....who originally derived Pi???
From
https://in.answers.yahoo.com/question/index?qid=20061028015950AAOxJD1:
The Egyptian scribe Ahmes wrote the oldest known text to give an approximate value for
π, citing a Middle Kingdom papyrus, corresponding to a value of 256 divided by 81 or 3.160.
The Chinese mathematician Liu Hui computed
π to 3.141014 (good to three decimal places) in AD 263 and suggested that 3.14 was a good approximation.
Archimedes of Syracuse discovered, by considering the perimeters of 96-sided polygons inscribing a circle and inscribed by it, that
π is between 223⁄71 and 22⁄7. The average of these two values is roughly 3.1419.
The mathematical constant π is an irrational real number, approximately equal to 3.14159, which is the ratio of a circle's circumference to its diameter in Euclidean geometry, and has many uses in mathematics, physics, and engineering. It is also known as Archimedes' constant (not to be confused with an Archimedes number) and as Ludolph's number.
The value of
π has been known in some form since antiquity. As early as the 19th century BC, Babylonian mathematicians were using
π = 25⁄8, which is within 0.5% of the true value.
It is sometimes claimed that the Bible states that
π = 3, based on a passage in 1 Kings 7:23 giving measurements for a round basin as having a 10 cubit diameter and a 30 cubit circumference. Rabbi Nehemiah explained this by the diameter being from outside to outside while the circumference was the inner brim; but it may suffice that the measurements are given in round numbers. Also, the basin may not have been exactly circular.
