- Jan 14, 2011
- Gillette, Wyo.
In response to the End-of-Lifing of several key components on the famous Rev "D" driver board, Joe set out to remedy this situation. Of course Joe never just "remedies" the situation, he surpasses his previous deeds well and spectacularly, this being one of those times. He has not only re-engineered the entire board, but has made it a better performer WITHOUT SACRIFICING that sound we love so well. Joe has had his 400 lab mule running for quite a bit longer than I have had the Pig running the new board....ahem....anyway....
I have had cable hell and some hiccups with the Pig, so we will be using Joe's measurements for all performance specs till i can correct some cable issues and get the Pig to behave. I will let Joe explain what he has done , but herein are some pics of the board construction and installation.
Fellas , I ind it amazing the degree of component change and the familiarity of the sound. There are some slight differences, the bass is tighter, faster, and better defined, the mids and highs remain pretty much the same.....EXCEPT for their abilty to handle....say....like some very loud flute passages on some Shpongle...which can at times drive me from the room or turn down the volume on the K's ( not my preferred option) are now doable at high volume. Overall impression is better overall defionition with a reduction in listener fatigue ( wasn't much to begin with) ......
Behold!! The Rev "E" driver board!!
Your baggage having thusly been carried you may proceed Joe!!
