Which wire Glen? And I was thinking about going with the 120 rail voltage 500 in the 700. With the MJ21196's , they might hold up....I've thought about it too. That's what led to the monster mono idea. The idea behind the monster monos was to drive a low ohm load all day long at hi power levels. The power supplies on the monsters are going to be built so I can add 2 more toroids per channel if need be...
If you put a 700 tranny in a 500 you would at least be able to spread a low ohm load over more outputs..
