pee pee on AR 6 grill
marcok
Milan Italy
Hi all,
one of the cats of my father made a pee pee spot on the grill of an AR 6 .
I need any suggestion to remove the spot .
Could hydrogen peroxide be a good solution ?
Ciao
Marco
Vinager to break up the oils, rinse with clean water and a spritz of Frebreeze
marcok
Milan Italy
Gamve ,
the cats had been already punished : they no balls and ovaries ( my father has four cats )
Besides there's the problem to find the guilty and contacting Gil Grissom to have a DNA analysis is
too complicated !:smile:
Northwins ,
in the next days I 'll test your solution .
I' m only afraid to demage the wooden chassis of the grill with the water ;
I will use a sponge very carefully .
Thank you and ciao .
Marco
marcok
Milan Italy
Przem ,
I have already seen the hydrogen peroxide solution on the web for cleaning mattress ,
but I prefer ask before to make a disaster . In any case I'll test both solutions on the rear part of the grill along the
chassis before .
Thank you and ciao
Marco
marcok
Milan Italy
Solved .
I have used trichlorethylene with a cloth and after water with a sponge .
Besides I have cleaned AR logos using a special rubber for model railway tracks
by Fleischmann . It' s also good to clean the PL's knobs .( already tested ) .
Ciao
Marco
P.L.F.
I love BIG amplifiers!
Hi Marco, I see - an obvious choice. I also want to clean something... ;-)
Trichloroethylene
Also known as: Trichloroethene; Ethene, trichloro-; 1,1,2-Trichloroethene; 79-01-6; Ethinyl trichloride; Trilene; Acetylene trichloride; Trichlorethylene
Molecular Formula: C[SUB]2[/SUB]HCl[SUB]3[/SUB] Molecular Weight: 131.38834
A highly volatile inhalation anesthetic used mainly in short surgical procedures where light anesthesia with good analgesia is required. [...] Prolonged exposure to high concentrations of the vapor can lead to cardiotoxicity and neurological impairment similar when taking drugs.
marcok
Milan Italy
Prezem ,
Obviously I have used this product in the garden , and the product that I have used is formulated
for domestic use . Typical for remove spots ( suggested by Mummy ).
Probably , if I have understood well , in Europe this product should be banned .
Ciao
Marco
