Sick Cyrus 2
Lazarus Short
Independence, MO
As I said in my amp shootout thread, I opened the bonnet on my Cyrus 2 amp and had a good look around. It has two bakelite caps which show cracking, and one electrolytic with a burned spot. I'm handy with a soldering iron, but can anyone tell me a good place to buy caps? What should I replace the bakelite caps with?
JustMike
"wherever she lets me"
"Just Passin thru"
Hey Laz,
I buy my caps from Mouser (http://www.mouser.com/). You can buy any amount you need if they are a stock item.
You may need a schematic and parts list to determine the values of those. Any good audio grade cap should be fine.
Its hard to tell sometimes if caps are bad just by looking without pulling them and testing.
gadget73
The markings on those brown things make me think they may be an electrolytic. Looks like 470uf 6v. They may be a non-polar though, I don't see markings to indicate direction. If you can make out a brand and/or a series number or something that may help identify them for sure.
but yeah, visual inspection may or may not tell you anything useful.
Lazarus Short
Independence, MO
Well, after all these months, I've finally gotten started at recapping the Cyrus. First off were the two bakelite caps - desoldered, removed, soldered in green Nichicon Muse caps. I put it all back together, except the top and front covers, connected the PSX, connected the Charlie for a source, and plugged in headphones. WOW! It never sounded quite right after it was fixed by the shop, but it did play music. Now it really sounds like music! Nothing blew up!!
I took the old caps over to the vice and cracked off the tops. Not surprisingly, they were bone-dry.
Lazarus Short
Independence, MO
Finished!
All the caps I ordered from Mouser are in place, nothing blew up, plus the amp works right and sounds right. It's taking its place in the main system as soon as I get the cabinet back together. Since it's going to be doing line-level duty only, I left the phono/RIAA sections alone - I'm very glad there were printed borders on the circuit board itself. The Arcam does a good job for vinyl, so their respective roles are set. The 46-pound Yamaha goes to Twangfest.
Lazarus Short
Independence, MO
Well, I've eyeballed the circuit board long enough to be familiar with the layout, and the dotted lines separating preamp, MC, MM, and RIAA are a big help. I can see the big pair of caps and four diodes for the power amp section, not now used (the PSX does the job), and the two small caps and their four smaller diodes for the preamp section. One of those small power-supply caps has a burned spot on the side, and though the amp sounds great, I want to replace those eventually. Do those need to be audio-grade, or will any kind of cap do? Anyone??
Not audio grade for PS caps Laz. You should find low ESR caps for those applications.
Lazarus Short
Independence, MO
OK, thanks! I was putting it back together and found the manufacture date: 03OCT1987, my daughter's birthday, but a year before. I shall call the amp "Octavia."
Lazarus Short
Independence, MO
It's fitting to show all of you the Cyrus in all its minimalist glory. The sound is glorious too with the Energy speakers. Eventually, I'll get around to the Vandersteens. BTW, the left hand unit, the amp proper, runs quite warm - I found out that it runs in class A/B.
