- Apr 28, 2013
Soooooo, I have one of these:
..and I came across this:
Bad, bad, bad glue!!!! Even though the amp is working at present, this looks like a problem waiting to happen. Figured I would document my repairs here for other folks that may have to do the same down the road. This will also make it easier for those of you that are kind enough to help me with this repair while I cry on and on about the "thingie on the whatchmacallit" and who has a spare bit lyin' about.
Here are a couple of links that show extensive work and mods done to this same model:
AK Yamaha DSBG Thread
Hope the OP at AK replies to my PM as he lives one town over from me.........sounds like he knows his way around these.
Jer's M80 Build
Here are some of the parts I may need to procure for this project:
C111, C112 | 220uf/6.3V | - I use Nichicon KZ's if possible, Any quality audio grade cap OK.
C162, C163 | 1000uf/100V | - I use Nichicon KW, KG, or FW, hard to find. (1-17-11) Digikey has FW in stock
D119, D120 | RD3.0EB2 3.01-3.22 20mA .5W | - use any .5W 20mA 3V DO-35 Zener (1N5225B)
R125, 126 | 390 Ohm .25W Carbon Film Flameproof (per schematic)
R137, 138 | 1K Ohm .25W Carbon Film Flameproof
R233, 234 | 430/470 Ohm .25W Carbon Film Flameproof (measure as the schem differs on these)
R123/229/231 - R124/230/232 | 330K Ohm Carbon Film
Often R226 | 2W 3.9K Metal Oxide Film | Mouser part link These are flame resistant.
Often C123, 124 | 39pf 500V mica cap | WIMA, Panasonic or any quality polypro or pps film cap
Usually have to remove and clean the busbars and TR113, 114, 123, 124 and replace a whole grip of jumpers.
Just an edit for the M-80:
R123/229/231 - R124/230/232 | 330 Ohm Carbon Film are 330k ohm
R125, 126 | 390 Ohm .25W Carbon Film Flameproof are 330 ohm.
(info lift from brutal's thread at AK- cheers)
Any other thoughts, input, suggestions are appreciated. More to come in the near- future as I really want to get her in the system sooner than later.
Jer's M80 Build
