- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
So recently I purchased a DBX-400 program route selector, as I'd like to start getting back into the general taping/recording aspect of our hobby here - Might be a reel to reel in my future radar, as an example.
That was errr.. about a month ago. Hadn't been paying much attention in that period.. no real critical listening sessions as I was also experimenting with digital sources, and specifically using DAC's as preamps with the DBX behind it for switching sources.
Finally half over a cold that's been kicking my butt for the past week, so today it was half past time to do some serious listening. In the process I noticed something.. bass sucked and that was with both WOPL 400's and 700's in play. Soundstage and instrument/voice placement was not as I remembered (when my dang ears were half "clear" before the cold I got over).
Then it hit me - it sure sounded like left and right were out of polarity/phase , like I had swapped the pos and neg outputs on one of the speakers. I then checked and triple checked the speaker lines - definitely hooked up correctly.
So what could it be, I asked myself. Ahhh.. it is that 400, even though it's purpose is strictly signal routing. Yep it does have processor loops and I did have an EQ patched into one, but none of that was in circuit... nothing that SHOULD alter the signal in any way, and yet...
Yanked it, and my bass and soundstage came back. HMMMMM...
So, "and so it begins"... I plan on seeing what I can do to enhance the signal handling in the 400. My thought.. it may be that the circuit has a coupling capacitor - one for each channel. Since caps in series with it do introduce a 90 degree phase shift, and if I do have a pair like that with either one short or the other open, I can see where it would cause the symptoms above.
Has anyone found a schematic for these DBX 400's?? That would be a big timesaver, otherwise I'll need to reverse engineer the one I have. Going to wait til tonight to begin - picks will be provided heheh.
