- Jan 14, 2011
- Gillette, Wyo.
Ok guys, while checking the 100 horse moter at the WD yesterday wiyth a Fluke 1577 Insulation tester the moter was supposed to be fine. Before changing out wire today we put a 60 horse by the drive, hooked it up and had the drive ramp the motor up and down and no problems. Hooked up the 100 after the new wire and same thing, DC bus overvolt.
Question, it is a TEFC motor that has taken a few saltwater showers, there may/may not be salt deposits in the windings, it will roll the moter for a few seconds till it trips on DC overvolt then a reset of that fault results in not even one revolution. Let things cool down(the drive obviously because the moter has not made a hundred revolutions and is cool to the touch) and it will rotate a few more. further investigation reveals a VERY ROUGH drive end bearing so it appears the motor can be at rest in a place wher it megs ok but a slight movement of the rotor can cause a shorting....The drive is a Yaskawa A1000 and has been running for two months. Can a motor exhibit these symptoms and still have good windings??
