Worked on the 2000 a little bit today.Added the Zeners to rectifier diodes and it brought down the voltage quite nicely to ~16V. Unfortunately still getting voltage leakage to the outputs. I thought maybe the new IC was fried from the previous high voltage so I swapped it out for the original. Now I have 17.5V at the rectifier diodes and I get a lot more voltage leaking to outputs. What is interesting is I checked the power transformer wires coming into the board and it is at 16AC and the after the rectifiers it bumps up to 17. Does that make sense?
Re-checked all my work and made sure all the capacitors I replaced were correct. Also re-checked the resistors and all are within spec.
Wasn't sure if I should try putting in the new IC's for the adapter I bought from Mouser. Not too sure if that would fix the problem and I don't want to burn those if the others are toast.
