As an Electronics Engineer I designed a new distortion less Preamp with Ambience rear channels... similar to the Phase Linear 2000, but much much better.
The overall design is 99% complete. Offered as a kit, also semi kit with tested PCBs, and also complete built and tested. That is posted elsewhere on this site.
The front panel and real panel are designed and look beautiful. Attached below. I'm added an array of XLR balanced inputs and outputs for best noise immunity. Those PCBs have just been ordered.
I also just designed a Balanced XLR output driver with a perfect RIAA Curve. Now you can put the turntable up to almost any length of XLR cable at Line level to a preamp with XLR inputs, or...use the XLR balanced Line receiver I also designed for this... changes it back to un-balanced RCA Jacks at the preamp if you don't have XLR connectors on the preamp. When this effort is done, I will release everything as kits with options as you want.
I work full time at Brookhaven National Laboratory and work on this project outside the job... Its a labor of love! I just added a few updates on the design for XLR connectors.
