Would This work?
rtp_burnsville
Savage, MN
Looks to me like a kit to basically insert a tube bias resistor without having to take the device under test apart. It allows the use of Ohm's Law to calculate the bias current by measuring a voltage across a series resistor of known value.
With Ohm's law if you know any two values of resistance, current, or voltage one can easily figure the missing value.
I = current in amps
E = voltage in volts
R = resistance in ohms.
E = I * R
I = E / R
R = E / I
Robert
