- Jun 12, 2010
- OZONE ALLEY MARS (Visitor)
- Wasted Days and Wasted Nights
I really like High-Gloss finishes. But they show every mistake. I'll tell you some tricks that may help you.
Dents- Take a wet cloth and put it on the dent. Then put an iron on it on high. And hold it there for a few minutes and it will pull the dent out. If the grain is broken it takes longer.
Water rings - When you get to the bare wood put bleach on the rings and let it soak. It will bleach the rings out.
Now for a finish you can't mess up. Watco danish oil. If you get a mark of any kind. Just sand the mark out and then put more oil on it you can't tell there was anything ever wrong.
The reason I'm bringing it up is I'm going to do my Labs when every thing is done. There is no finish on them. So I will take 0000 steel wool and rough them up a little then I will wipe them down with a tac cloth. Then I will use use Watco natural oil on them. I will put the oil on with 600 grit sand paper. It will make the finish as smooth as a babies behind. Then ever so often I will wipe them down with more oil.
Larry
Larry
