62vauxhall
- May 14, 2014
- Southwest Kootenays BC
Wanted to adjust the idle current of this Akai receiver I was given. Rotating the pots (they seem fine) had no effect. According to SM, the objective is 40mA (not mV) and I only get 20mA.
It was suggested that these VD1222's are failure prone but how do you test them? Diode check function is OL both direction and ohms are 4M for one and 7M the other.
What further confused me is the VD1222's schematic symbol is 3 diodes in series and the parts list description is thermistor.
I comprehend the intended function of regulating current based on heat and what I've read about thermistors says that's exactly what they do - increase and decrease resistances as they heat and cool.
But why the triple diode symbol on the schematic?
Additional reading (and there's not a lot to read) about VD1222's called them "double diodes" and substituting two IN4148's in series is acceptable.
Does that sound right to you guys?
