Used Test Equipment from a Mad Scientist Lab
Sunnbobb
Mount Vernon, WA
Bikes, baseball and big amps.
A couple months ago I purchased the estate of a well established EE. He specialized in microwave and audio. I just finished inventory of the big gear, and am getting ready to move it. I thought some folks here might like a shot at it before I take it into the market. Here is a list of all the gear. Most of it was connected up and operational when I went to disassemble his lab. I took me almost five hours to disconnect everything, and four truckloads to move it. The prices are low eBay sold prices for working gear. I can likely go 15-20% under that since I won't be dealing with eBay fees. If you need a reference, my seller ID on eBay is i2i-sports, where I have a 100% feedback rating on over 5,000 transactions. You can also see all the peripheries *resistors, wire, small test gear, connectors etc... that came with this gear, as I slowly get it all listed.
You can PM me here, and we can proceed to discuss via email after that. All transactions will be through Paypal to protect both the buyer and seller.
thanks!
THE LIST:
BOONTON 9200B RF voltmeter $165
EG&G Princeton Applied Research 5208 Two Phase Lock-in Analyzer $385
EIP 578 10 Hz - 26.5 GHz Source Locking Microwave Counter $1450 CHECK SPECS
EIP 924 Microwave Source 3-12.4 GHz $300
Fluke 6062A Synthesized RF Signal Generator $425 ea (2)
Fluke 6071A Signal Generator $425 ea (2)
GW Instek GPR-3510HD DC Power Supply $375 check
Agilent 6205B Harrison Dual DC Power Supply $135
HP 141T DISPLAY SECTION W/ HP 8553B RF Spectrum Analyzer & HP 8552B IF Spectrum Analyzer $325
HP 141S DISPLAY SECTION W/ HP 8554B RF Spectrum Analyzer & HP 8552B IF Spectrum Analyzer $425
HP 141T DISPLAY SECTION W/ HP 8556A LF Spectrum Analyzer & HP 8552B IF Spectrum Analyzer $325
HP 3325A SYNTHESIZED FUNCTION GENERATOR $450
HP 3468A Bench Top Multimeter $85
HP 5328A Universal Counter 500Mhz $95
HP 6443B DC Power Supply 0-120V 0-2.5A
HP 8018A Serial Data Generator $198
HP 8444A -OPT 059 TRACKING GENERATOR $185
HP Agilent 85046A S-Parameter Test Set 300KHz to 3GHz $900
HP 8554B 100kHz to 1250MHz RF Spectrum Analyzer Plug-in $75
HP 8555A RF section $85
Hp Generator Sweeper 8601A $165
HP Hewlett Packard 8713C RF Network Analyzer $1850
HP 8750A Storage Normalizer $35
HP 8752B Network Analyzer $625
HP 8753C Network Analyzer $625
HP Hewlett Packard 8970B Noise Figure Meter $585
INSTEK 30308 PULSE GENERATOR
Ithaco 1201 Also known as DL Instruments 1201 - Low Noise Voltage Preamplifier $425
OMEGA DM500 DATA LOGGER $275
Princeton 129A 2 Phase/Vector Lock In Amplifier $195
Pulse Instruments PI-720 programmable bipolar DC source plug-in for the TM500 system. $85
Racal-Dana 9303 True RMS RF Level Meter $149
WAVETEK ROCKLAND SYSTEMS CORPORATION MODEL 452 DUAL HI/LO FILTER $245
Tektronix 067-0885-00 - Microwave Comb Generator $125
Tektronix/Sony 323 OSCILOSCOPE $135
Tektronix TM502A Power Module Mainframe $145
Tektronix SG 503 Leveled Sine Wave Generator Plug-In Module for TM500 $225
Tektronix TM503 check
TM 501 POWER MODULE $200
TENMA 72-2075: Laboratory DC Power Supply (2) $75 EA
TENMA 72-4050 Am/Fm stereo signal generator $325
Topward TPS-4000 Dual Tracking DC Power Supply $275
WATKINS JOHNSON WJ-1204 SYNTHESIZED SIGNAL GENERATOR $385
Wavetek Model 23 Synthesized Function Generator $185
Wavetek 5830A Digital Signal Analyzer $180
